NightMaker Skrivet 10 Augusti 2004 Rapport Dela Skrivet 10 Augusti 2004 (redigerat) jag kommer att få en ation replay till gba så jag behöver lite koder till pokemon ruby/sapphire ';....;' :...: Redigerat 10 Augusti 2004 av robban83 Länk till kommentar Dela på andra sajter More sharing options...
mario Skrivet 10 Augusti 2004 Rapport Dela Skrivet 10 Augusti 2004 Här komer coder: Pokemon Ruby Master Code : DE00AAFD 2EBD05D0 530823D9 16558191 Pokemon Sapphire Master Code : DE00AAFD 2EBD05D0 B4564EFE 23F44BF2 1.1.1 Always Male/Female Codes.* ------------------------------- If you use theses codes, Nintendo might know that your Pokémon has been hacked. Enter one of these codes and you'll set the gender of the next wild Pokémon you'll see (if it has any gender or course). Note : It can still be Shiny, with a chance of 1/8192. Always Female Pokémons Code : 0C3D5307 ABB44D7C 78DA95DF 44018CB4 Always Male Pokémons Code : 0C3D5307 ABB44D7C 141BB87C 83D7018F 1.1.2 Always Maxed Genes Codes.* ------------------------------- If you use theses codes, Nintendo might know that your Pokémon has been hacked. You can only enter one of these code at the same time. Gene Maxed Out (value of 31) for wild Pokémons: HP Gene : 28330312 B9E777D4 141BB87C 83D7018F Attack Gene : BD34E89C 46AC3FDD 141BB87C 83D7018F Defense Gene : C5F9E49A 1DC472F1 141BB87C 83D7018F Speed Gene : 05DF5C70 440053F5 25260C8D 25207DAE Special Attack Gene : 0526A00A F717AC06 141BB87C 83D7018F Special Defense Gene : 3362EF2D D6B8C92E 141BB87C 83D7018F All Genes Maxed Out : AB5FF5EF A7716843 4B5258BD DBEA8F6E 1.1.3 Pokerus Code.* ------------------- If you use theses codes, Nintendo will *not* that your Pokémon has been hacked. Use this code to make ALL your Pokemon catch the Pokerus after a fight. (even if they already caught it) C784FC61 63EBC3B6 117279A9 85478753 And here are some explanations about the Pokerus : The Pokerus is a virus that infects Pokemon. But it's not a bad thing : when a Pokemon has caught the Pokerus, the Effort Values it gains after a battle are doubled ! You see if your Pokemon has the Pokerus by looking at its summary. If you see "STATUS PKRS" under its picture, that means your Pokemon is infected. To make the Pokerus spread, take the infected Pokemon in your party, and make some battles. After each battle, the other Pokemon will have a chance to get infected by the virus. The virus will disappear after about four days. At this moment, the "STATUS PKRS" will be gone, but you'll see a black dot to the left of its level's number. That means three things : - this Pokemon will never be able to be infected again, - that it'll stop to infect other Pokemon, - that its EV gains are doubled. If you put an infected Pokemon in the PC, the virus will not spread, but the infected Pokemon will not loose its Pokerus Status. There are two ways to get infected by the Pokerus : - Find a RL Friend whose Pokemon has caught the Pokerus, and ask him to give you one of his infected Pokemon. Make the virus spead to your Pokemons, and then give him his Pokemon back. - Make a lot of battle. After a battle, you have 1 chance out of 21845 (more precisely 3 chances out of 65536) that one of your Pokemon get infected by the Pokerus. This is very very rare. As a matter of comparison, you have 1 chance out of 8192 to find a shiny Pokemon. Länk till kommentar Dela på andra sajter More sharing options...
Gäst anubis Skrivet 10 Augusti 2004 Rapport Dela Skrivet 10 Augusti 2004 köp en kod guide. Länk till kommentar Dela på andra sajter More sharing options...
mario Skrivet 10 Augusti 2004 Rapport Dela Skrivet 10 Augusti 2004 Här komer mer: 1.1.4 Select Ability Code.* -------------------------- If you use theses codes, Nintendo *might* know that your Pokémon has been hacked. You might know that each Pokemon has 1 or 2 abilities (Pick Up Items, Run Away...). You can't give a Pokemon an ability that he can't have, but you can choose which ability you prefer when a Pokemon that has 2 abilities is created. Use this code to get the 1st ability : 1801D754 AFDD78F8 8E883EFF 92E9660D Use this code to get the 2nd ability : 1801D754 AFDD78F8 AD86124F 2823D8DA If a Pokemon has only 1 ability (most of them do), these codes won't do anything. If you use theses codes, Nintendo *might* know that your Pokémon has been hacked. Put 2 Pokemons that can breed into the Day Care (located on Route 117). Enter one of these codes, and wait for the egg to be created (walk around). Once the old man is telling you he has an egg for you, press R or L (see below) during the dialog to get the desired effect : Code #1 Press R to have a Female Pokemon in the egg : 7A2C40E4 06AFEFA1 9AB20DC0 97849B9B Code #2 Press L to have a Male Pokemon in the egg : A0F59292 AB07DEFE A88D8B3A 975E4033 Special Notes : - These Codes only work for Pokemon that have a gender! - You can also use the Fast Egg Hatch codes to get the desired Pokemon very fast :) - Be aware that you can't use the Always Shiny Pokemon Codes on an egg created with these codes, else any effect of the Day Care Codes you used will be erased. Now a bit of explanation about breeding and eggs : When you put 2 pokemon that can breed in the Day Care, they can make an egg. The Egg creation is random, and occurs when you walk. When the egg is created, the game stores a random number (1-65535) somewhere. Then, when you take the egg from the old man, another random number (this time 0-65535) is computed. The game put these two numbers together, and use them to create the Pokemon (for people that used to read the japanese Pokemon thread on cmgsccc, the 2 numbers will become the MAP). Moreover, as the numbers are random, things like shinyness, gender, or traits wont be given by the parents to the child. So breeding 1 or 2 shiny Pokemon won't give more chances to get a shiny child. 1.1.9 Select Personality Codes. ------------------------------- If you use theses codes, Nintendo should *not* know that your Pokémon has been hacked. Once you've enter one code, all the Pokemons you'll encounter will always have the personality you choosed, until you reload your game. This does not work for Pokemon that hatch from eggs, and for Pokemon that don't appear randomly. Hardy : 8CA19DF6 CAAA4B16 D0E34D66 5796A7D3 Lonely : 8CA19DF6 CAAA4B16 D73BC50A 5F47AA0E Brave : 8CA19DF6 CAAA4B16 E485844D 2F24038C Adamant : 8CA19DF6 CAAA4B16 5EB8DEEE 692ED298 Naughty : 8CA19DF6 CAAA4B16 83286B46 6479AA98 Bold : 8CA19DF6 CAAA4B16 35EB915F 08F33974 Docile : 8CA19DF6 CAAA4B16 A58F6F1B BFB13FEF Relaxed : 8CA19DF6 CAAA4B16 34027F23 7E7E1599 Impish : 8CA19DF6 CAAA4B16 CDA2AB99 F89D5BB9 Lax : 8CA19DF6 CAAA4B16 D593BF29 E18AAAE5 Timid : 8CA19DF6 CAAA4B16 1BC372C9 06B4D17F Hasty : 8CA19DF6 CAAA4B16 D4950A99 D729D80A Serious : 8CA19DF6 CAAA4B16 93F04759 F95753D9 Jolly : 8CA19DF6 CAAA4B16 E9EC2CBF A7EDD4A7 Naive : 8CA19DF6 CAAA4B16 56F744B0 37E16732 Modest : 8CA19DF6 CAAA4B16 E1EB2109 4480C28D Mild : 8CA19DF6 CAAA4B16 A2461E51 304137B6 Quiet : 8CA19DF6 CAAA4B16 0456554B 66D3AAF9 Bashful : 8CA19DF6 CAAA4B16 B05B4CCD A0A1505B Rash : 8CA19DF6 CAAA4B16 909149AB 2DE8726A Calm : 8CA19DF6 CAAA4B16 31F62F82 D9A0C100 Gentle : 8CA19DF6 CAAA4B16 9A41D845 41B93FE6 Sassy : 8CA19DF6 CAAA4B16 D47DA721 6C3B9FFC Careful : 8CA19DF6 CAAA4B16 1A15BF1E E72650E4 Quirky : 8CA19DF6 CAAA4B16 5A7B2626 21ECD183 Länk till kommentar Dela på andra sajter More sharing options...
Gäst anubis Skrivet 10 Augusti 2004 Rapport Dela Skrivet 10 Augusti 2004 därfick han ju hela kod guiden! :P Länk till kommentar Dela på andra sajter More sharing options...
mario Skrivet 10 Augusti 2004 Rapport Dela Skrivet 10 Augusti 2004 nånå det fins ju typ 50gånger så mycket att skriva ska jag det? fast det är riktigt jobigt! jag shäner mig som en slav! Länk till kommentar Dela på andra sajter More sharing options...
NightMaker Skrivet 10 Augusti 2004 Författare Rapport Dela Skrivet 10 Augusti 2004 nånå det fins ju typ 50gånger så mycket att skriva ska jag det? fast det är riktigt jobigt! jag shäner mig som en slav! behövs inte här är 40 poeng :cool: Länk till kommentar Dela på andra sajter More sharing options...
Naruto Skrivet 10 Augusti 2004 Rapport Dela Skrivet 10 Augusti 2004 (redigerat) oh... leafgreen :D .... men den e ju amerikansk! man ser det på den texten gameboyadvance, advance texten e svart! Redigerat 10 Augusti 2004 av Kite Länk till kommentar Dela på andra sajter More sharing options...
NightMaker Skrivet 10 Augusti 2004 Författare Rapport Dela Skrivet 10 Augusti 2004 oh... leafgreen :D har fire red också titta sjelv Länk till kommentar Dela på andra sajter More sharing options...
NightMaker Skrivet 10 Augusti 2004 Författare Rapport Dela Skrivet 10 Augusti 2004 nånå det fins ju typ 50gånger så mycket att skriva ska jag det? fast det är riktigt jobigt! jag shäner mig som en slav! sej bara sidan där du fick alla koderna i från <_< Länk till kommentar Dela på andra sajter More sharing options...
Ratiasu Skrivet 10 Augusti 2004 Rapport Dela Skrivet 10 Augusti 2004 Jag ha sett många sidor me koder och d första dom visar e Master code!Va e Master code egentligen??? Länk till kommentar Dela på andra sajter More sharing options...
